Results 1 to 14 of 14
Thread: 2015-2017 control pack rev limiter issue
    Hey guys, I'm having issues getting my gen2 coyote to rev past 7000 rpm. I have the cutoff set at 7800 and the temperature base stuff set at 7800 as well. Can someone take a look at my tune and see what I'm missing? Thanks!
    2018manifold.hpt
    Dec 2017
    767
    Just got off work I’ll ck it out as soon as I get home
    Ok thanks much!!
    Dec 2017
    767
    load this and try it and log it and post log file please
    Ok, thanks! I tried that and it was basically the same. Here is the log file, hopefully I logged the correct PIDS.
    wot.hpl
    Feb 2012
    TEXAS
    637
    try increasing your min and max torque to 650, and cylair wot multiplier to 1.99 and manifold volume to 11.960, also try raising the Max torque table see if any of those help
    Ok I'll try those changes. I do have a 2018 manifold on the car, and was under the impression that those were 12.5L?
    Dec 2017
    767
    from there log you sent with my updates it closes throttle at 7140, I did everything I’ve done to prevent this from happening. So I’m scratching my head
    Jan 2013
    Hawaii
    2,101
    no vehicle speed sensor input, ECU thinks it is in neutral. Raise that RPM.
    Dec 2017
    767
    Raise the neutral cut off like Murfie suggested, I didn’t think to change that.Let me know how it goes.
    Neutral cutoff fixed it! Thanks guys for the help.
    Dec 2017
    767
    How did it feel I made a few tweaks to the file
    Quote Originally Posted by Bill88stang View Post
    Felt really good to be honest! Best it has to date. I did notice the idle started hunting a tick. Played with it and it is happy now. Thanks much for the help!
    Dec 2017
    767
    No problem glad it felt good
