2010 ZR1 track car was here for oil system improvements due to oil starvation on high banked ovals. The car ran strong before disassembly to install improved racing windage tray, baffle, tank baffle, t-stat remote oil cooler, Katch red pump, and freshen the engine. No cal was flashed since the car was here this time, the car tuned for flex and ID 1000 injectors a few years back and ran strong. Now I have no fuel pump prime / no communication to the fuel pump controller after reassembling the car. The codes I get are P0230 and P069E. After reading the forums it looks like the re flash from the ECM may be causing FSCM problems, but I am not sure how to tell. I can't see where to load the FSCM file, does it load with the regular cal? I included the current cal and infolog. Anyone been down this path already or can offer suggestions? Thanks! Ed.
