Page 3 of 3 FirstFirst 123
Results 41 to 56 of 56
Thread: Fuel Economy and Less Regens
  1. #41
    Tuning Addict
    6,774
    I'm far from done with it yet. I plan on wideband, reinstalling stock intake, logging afr to maf cells, installing S&B again - logging for correction, unplugging a certain something and then restarting Discovered some things while going over logs that finally clicked "for some stupid reason" while I was comparing hpt's tables to EFI Lives..... This all depends on the dealership finally fixing the engine of course too - injectors damaged something while they were acting up - fired it up one cold morning with the bad ones and it went to knocking and bouncing the front of the truck up and down for about 10 or so seconds before smoothing back out - was hoping I got by without damage, but doesn't appear so as it now has a pecking/knocking sound "sounds like a wrist pin knock" and it's still showing light throttle misfires on cylinders 2 and 3 after they installed the new injectors :/ Really losing faith in this motor.....
    ~Greg Huggins~
  2. #42
    Jun 2018
    Albuquerque New Mexico
    465
    When did your engine start acting up? Was it acting up during the time you were tuning and posting data on here?
  3. #43
    Tuning Addict
    6,774
    It had bad injectors again or going bad injectors again just before I started messing with it, which I 100% know kind of throws things out the window... However it did help open my eyes to some things with how it was performing, soooo... Knocking wasn't present until I was driving it with the stock tune a couple of days after getting it back with the new injectors... Truck went to hopping up and down the week prior... Even then it fired up and ran smooth for maybe 4 or 5 seconds and then one stuck open - ran that way for 10 to 15 seconds without load and then went back to purring like a kitten... Truck was on stock tune before and after injector replacement because I wanted to take it to them with the codes present and set for the misfires and driven stock 1 week after when knocking was first heard... Only originally heard knocking / pecking noise in stop and go traffic 2 days after replacement... Assume damage was done on that rough cold start morning with the stock tune... Starting doing research into these motors and found some of the first ones had wrist pin, piston, rod bearing issues on top of injector problems - something in manufacturing/tempering of parts... Most engines with these issues are showing problems anywhere from 60 to 80some thousand miles on the odometers where pins are ovaling, collapsing, cracking / letting loose - conveniently just out of most peoples warranties... GM is keeping this under wraps, but have let it slip to some... So far that I know of these engines have piston/rod pin issues, turbo unison rings sticking and bending issues and injector problems... I did get the new part number for the injectors and have never had any turbo problems, but piston and rods are up in the air at the moment....... Like I said before, not sure if I'll still have this truck after this is all said and done or another smaller chevy diesel in general Too many corner cuts lately with this company or it's just simply a supplier problem as I know some engineers and they've said that even in the last 3 months companies all alike have been having metallurgy issues with parts coming from certain parts of the world where they're seeing very fast premature wear... I've even gone as far as reaching out to AM companies already to find out how much a set of pistons would cost to get made - it's about $500 per piston if anyone's interested and then a set of $800ish rods...
    To date while my truck has been 100% stock, I have had backup camera problems, transmission lines explode, Nox sensor issues, rear pinion bearings fail, multiple flash updates, alternator go out, 5th injector leaking causing a drastic loss in economy and now two sets of injectors all go bad with 87000 and some change on the odometer... I also don't believe you'll find anyone take as good of care of one... Maintenance has been hotshot, diesel clean, howl's, and now schaeffer fuel additives, ran the junk dexos oil up until 50000 when I changed to the extremely good schaeffer euro 5w30 oil with MOA additive "worth it's weight in gold", 2 tcase services, 2 diff services, 2 trans internal filter services, 2 induction/egr service's, 2 crankcase flushes with turbo cycling... Turbo shaft and bearings were very tight and spun very very easily when I installed the S&B a month ago... Not to mention all of the fuel filters that were spotless and airfilter services... Not to mention all of the highway this thing sees... I'm a firm believer in maintenance and until this vehicle has never let me down :/
    Edit - post #5 is when I discovered my injectors going bad again...
    ~Greg Huggins~
  4. #44
    Dec 2005
    602
    What is the richest lambda value that the diesel gauge would need to display ?
  5. #45
    Tuning Addict
    6,774
    I'm pretty sure most target around an 18:1 afr, so 10 or 12 should be beyond rich enough for displaying purposes. As for logging maybe a touch richer, but don't see the point other than correction factors?
    ~Greg Huggins~
  6. #46
    Jun 2018
    465
    Quote Originally Posted by dr.mike View Post
    Yes i agree with GHuggins 10-12AFR at the lowest would be fine just to know how far off we are, just in case i accidentally fat finger some numbers. lol.
    Wow Ghiggins that's some crazy issues with your truck! I'd be upset if i had half of those issues! So are you on the hook for fixing the truck or is GM?
  7. #47
    Tuning Addict
    6,774
    Don't know for sure yet... I've got gmpp which is nothing more than a gm warranty that your have to pay a deductible on... SM at the dealership has already given me some crap, tech says he's going to do his best to get me taken care of - it pays to have friends in the dealership Other than that - I'm not 100% sure... Tech has heard and confirmed the noise / issue as being present when he rode with me - you can even feel it in the floor board, SM called me up and said nothing was wrong and had to come get it and give his loaner back - tech then said to ignore him and he would take care of it as well as gm would allow him to, Soooo...
    ~Greg Huggins~
  8. #48
    Dec 2005
    602
    OK. So :
    1. Stoic ratio for AFR = 14.5
    2. Lambda digit range 0.000 - 6.999
    3. AFR Digit range 8.0 - 99.99
    4. Analog output 0.5v = 0.5lambda 4.5v 0 4.500lambda ( makes tranform math REAL easy )
    5. needle LEDs maybe 12afr- 95afr (~ 0.8lambda - 6.5lambda )
    6. Serial data 0.0-99.9AFR
    7. Never goes " - - -"
    Would that do it ?
  9. #49
    Tuning Addict
    6,774
    Looks good to me, but I'll let Jaeger confirm for sure...
    Only question I have is how well the sensor may hold up in the exhaust since diesel egt's are regularly in the 900 to 1200 range - guess it could be lifted out via extension slightly? Thoughts?
    I'm personally glad to see this happening - I always prefer good data for tuning... I still need to get back with hpt and see how the table adding is going or not going... Thank You as always Dr.Mike
    ~Greg Huggins~
  10. #50
    Dec 2005
    602
    The sensor's heater tries to keep the sensor element at 650C (1200F). If the EGT's go higher than that, the controller will lose temperature control of the sensor (error). I would, probably, add one of those Innovate bung-extender/heat-sink doodads. And, maybe, move the bung further down-stream.
    It's rapid temperature swings that kill the sensors. They, actually, prefer to be, a bit, on the hot side. But, they HATE rapid heating/cooling.
    It's the soot/particulates from a diesel that I worry about. Maybe someone would want to run a periodic sensor calibration test procedure to log the results.
  11. #51
    Oct 2019
    3
    Sorry for the newbie question, but does anyone know if these principles would transfer to an LML? My truck is 100% stock, just would like a little better mileage and better pedal response.
  12. #52
    Jun 2018
    465
    Yup it always pays to have someone on the inside of a dealer! It's better to have the tech on your side than a SM IMO, because the tech really has the final say of doing the job or not. SM's always want the money and hrs so if the tech says ill do it, it'll get done.
    OK. So :
    Would that do it ?
    Yup That's perfect! I'm really excited to get one, send it to you dr.mike and try it out! I'm also curious how the soot will affect accuracy over time but i do have some of those old heat sink bungs laying around. We'll see if that helps and I'll try to record some data on accuracy over time.
  13. #53
    Jun 2018
    465
    Quote Originally Posted by jeek View Post
    What principles are you inquiring about?
  14. #54
    Dec 2005
    602
    OK.. I think I have the diesel patch worked out.
  15. #55
    Sep 2018
    213
    Better fuel economy = nox emissions more nox = more EGR and SCR
    More EGR = more soot
    More soot = more regens
    More regens = more fuel
    I might be wrong (haven't tried tuning a emissions diesel) but I don't think what your after is not possible. I think regulations/components on a ATD/SCR make both impossible. Maybe one or the other, but not both.
  16. #56
    Jul 2019
    New Zealand
    15
    Hi GHuggins how did you get on with your timing changes in the end?
    I’m tuning my 2.8 at the moment and have done something similar to you with the timing.
    Did you continue to run that more advanced timing at the low rpm range with positive re
