Results 1 to 7 of 7
Thread: Here is a 2018 Q60 SILVER Sport(300hp) base file.
    May 2009
    454
    Here is a base file from a 2019 Q60SS.
    Q60SSbase.hpt
    Also here is a tip when reading/writing. I am an Infiniti master tech/service manager. Whenever we perform factory ECU updates, the fans ALWAYS turn on causing a massive power draw and these vehicles are very sensitive to voltage. What we do in the shop is remove the fans relay before doing a read/write. I noticed the fans do the same thing when doing a read of the vehicles. You will need two very small screw drivers or picks and just push down the tabs on each side and pull up on the relay and it comes out.
    I will post a stock red sport 400hp stock file tomorrow once I go to work and read one.
    2018 Infiniti Q60s
    2004 350z/LS2: ERL 434ci, 11.8:1,TFS245cc,262/266@113+3,Fast102,NX 102 plate,60#injectors/return w/twin 255s
    Old setup: CNC'd317s, Fast 102, 228/228@114, PT88,83#injectors/full return system. 10.84@138
    Jan 2009
    Kansas City
    47
    I went to try to open this .hpt file but it gave a message "Unable to open file. You are not authorized".
    Is the file locked for some reason or do I need to buy something before I can start viewing files?
    I wanted to have a look at this because I am still trying to decide which tuning software I want to go with, to tune my 2018 Q50 3.0T Luxe. I have some experience with HPT on the LNF motor. But it's been years since I have last used HPT.
    May 2009
    454
    It's not locked.
    2018 Infiniti Q60s
    Apr 2015
    I got the same message "unable to open, you are not authorized", all other files I've downloaded on this sub have opened fine.
    Quote Originally Posted by frostycrowd View Post
    You have to have an MPVI2 plugged in to open the file. All new market releases require this
    Nov 2009
    Jeddah, Saudi Arabia
    2,274
    use latest beta
    E-tuning/remote Tuning Sultan@mastuning.net Follow @MASTUNING Contact/Whatsapp +966555366161
    [URL="http://www.mastuningsaudi.com"]
    Aug 2014
    6
    Quote Originally Posted by Snyper View Post
    Q60SSbase.hpt
    Do you have the redsport file posted or is it in the repository?
