Results 1 to 7 of 7
Thread: 2016 GMC SIERRA KR* can't eliminate
    Jun 2019
    4
    I have 2016 GMC Sierra single cab
    mods:
    Air aid CAI
    Cat delete + cat back
    I have a lot of KR* I expect the KR* from TQ tables (driver demand, peak engine torque and VVT coeff...etc)
    I am not expert with Gen5 GM ecu please guys check attachment and give me your opinion
    Jan 2019
    White Hall, Arkansas
    73
    The 4800 rpm area is very prone to knock. It's normal to see a couple degrees less timing in this area from .60 to wot. Most of your table looks a little high to me unless your are running some really good fuel.
    Oct 2019
    Mississippi
    24
    I’m new to the gen v tuning as well but have you dialed in your VVE and MAF using a wideband ? Check your LTFTs, fueling could be way off .
    13,565
    Do you have a wideband in the exhaust to see what your real time air fuel ratio's are?
    Having the timing tables mirrored doesn't help the knock either, once it knocks it can't get rid of it because the tables are the same. It can remove some but then slams it right back in once's it gone and the knock can return again.
    Jun 2019
    4
    I reduce peak engine torque and I got little better.
    Jan 2019
    73
    Looks like you added your burst retard back. Then you bumped your minimum spark table to 21 degrees at wot. Not smart. You need to take your minimum spark table back and pull timing in the areas that show KR.
    As an experiment, richen it back up some.
    If you're actual air/fuel ratios are in the ballpark of what you're commanding, my experience with LS & now with these LT truck engines is that they like to be a little richer than where yours is at.
