I have attached the Tune, and Scan,, would like some help reviewing.. I have done a tone of self schooling, and knowledge building..
Here is about the car
2009 srt8 6.1 6 speed. Drivability is awesome with tune so far.
Has the following
belanger long tube headers, high flow cats, flow master mufflers
Centerforce Dyad clutch and light weight flywheel
running 91 costco with boostane set to 96 oct.
K&N fipk cold air intake setup
installed a AFR500 wideband setup on lambda mounted top side, just 2" closer to engine from the B1S1 location for reference.
Timingchange1.hptShare6.1part1.hpl
i have access to zoom if that helps.
Only codes im getting are p0430 and p0420.. .. which prior to tune with OEM tune and 91 fuel , never would toss codes..
