Results 1 to 2 of 2
Thread: What else should i be monitoring?
    Jun 2016
    6
    recently got my car running great although i'd like to iron out all the small things now. I'm sure the car is running a bit rich as I have fouled some plugs. Would it be safe to pull 5-10% of fuel out and go from there? I unfortunately don't have access to a wideband at the moment but it is on the list for the future.
    228r, 243s, LS6 intake, 28lb injectors, runs great.hpt
    228r tsp tune 28lb drive around the block, feels great.hpl
    13,564
    Not knowing where to remove fuel is your problem, so I wouldn't do a lot until you get a wideband. It may be tough to do fuel trim tuning depending on the exhaust setup. You've done this much already, what's $160-170 for a wideband to make sure nothing goes wrong.
