60 lb Deka injectors that come with ECS kit. I was directed to use the Fuel Injector Connection data (same data is also available on the A&A website). When using that data the fueling was way off and my fuel trims just kept climbing to -30%. I had tuned the car before adding the blower so the VE was pretty close and I wasn't expecting much of a change if the injector data was good. Curious if anyone has used that data with success. I've attached 2 tunes, one is a startup tune with injector data that seems to work, the other is a startup tune with the FIC data that I'm supposed to be using.
Anyone have the correct data for these injectors? I'm leaning towards using the data in the tune that seems to be working but would be great to know what the correct data is. Thanks
Copy of FIC650CC-60LBBOSCHEV14LSXHPT.xlsx
2002 Z06 2 bar base tune blower ECS3.1.hpt
2002 Z06 2 bar base tune blower ECS3.1 FIC inj data.hpt
