Hi,
Does anyone know where the true MBT map is located in Dodge ECU? I'm looking at the map that is under Spark>Advance>MBT>Base vs Spark>Advance>Part Throttle>Base map and I see that the values for low RPM low load region are exactly same, which I find weird, hence the question.
