Long story short I got asked to tune an LS swap going into an older Impala/Camaro/something, I can't keep straight what this one is going into honestly.
The engine and PCM are out of a 2000 Firebird firebird auto
The car it's going into is a manual
The issue I'm having is it won't go over 2K RPM's. I feel like it's something in the transmission settings but could be wrong.
Does anyone have any ideas? Logs/tune attached. Timing and injector PW's don't drop off in the logs but it's literally exactly 2000 RPM's where it cuts out, so I assume it's cutting the injectors or something.
The tune is probably crap at this point, I was changing everything I could think of to try to get it over 2K. I'll finish tuning it correctly once I get this issue taken care of.
The PID's are limited on these than I'm used to on gen 4 and 5 stuff.. on those you can log what's triggering this but I couldn't find any PID's like that on this one.
Any help would be much appreciated. Otherwise I'm going to spend the $100 and license a different file to dump on this PCM from another P01 with the same setup that didn't give me this issue.
The only thing I've really thought about changing since I was out there last was the torque reduction tables under transmission --> torque management, i.e. [ECM 15400]. I've noticed those are very different on some other P01's I've tuned without issue. I thought those would be disabled with disabling abuse mode but maybe not.
Thoughts? Suggestions? Am I the idiot missing the obvious?
5741, AJ's, Read (2019-09-26).hpt
19-11-06 19-04-27.hpl
