Results 1 to 8 of 8
Thread: negative response code
    Jul 2016
    edinburgh scotland
    29
    i have changed a 2008 roush supercharged mustang from automatic to manual mechanically it is sound but have an issue with the tune. i have changed the pcm and purchased a new engine harness. as the orginal tune was for the auto i soursed a manual tune which i have tried to write to the pcm but evertime i try i get the following message "write transfer request x7 negative response code. can anyone give any advice or herlp please on what this message actually means and what i can do. many thanks in advance
    mike
    Mar 2019
    Tierra Verde, FL
    157
    Someone on this board should know. In the meantime create a support ticket to HP Tuners and see what they say.
    Dec 2011
    San Antonio, TX
    319
    This is typically a battery/low voltage issue.
    JTC Performance - Authorized HP Tuners Reseller
    Remote performance tuning
    Jul 2016
    edinburgh scotland
    29
    Quote Originally Posted by charcoal03silvy View Post
    many thanks for your reply i will check the battery and sure hope this is the issue
    Oct 2016
    Poland
    1,743
    Quote Originally Posted by SHMUSTANG View Post
    mike
    Automatic PCM can be switched to Manual with no problem - you don't need a second ECU. The other way around is a different story.
    Jul 2016
    edinburgh scotland
    29
    many thanks the only reason i changed the pcm as i was told by a tech at ford i would need to change the pcm and the harness, i look through the file and noticed that i could switch the auto off. unfortunately i still have the issue after making sure the battery was fully charged
    Feb 2018
    Kuwait
    98
    Have you identify the pcm to vin #?
    Jul 2016
    edinburgh scotland
    29
    yes i have identified the pcm to the vin as i could change things in the tune file. when i installed the new engine harness that is when the problems started
