Results 1 to 4 of 4
Thread: Bug or end user?
    Aug 2018
    North-Western Kentucky
    13
    Bug or end user?
    I'm not sure if this is a bug or if I'm doing something incorrectly.
    While tuning my VE table, I am trying to copy specific cells using Ctrl + Click and then "Paste Special > multiply by %-half". When I paste, it pastes the entire table, even though I have only selected specific (high value) cells.
    If I attempt to do this by selecting just a few cells at a time, it will work a time or two and then eventually paste the entire scan table into the editor, regardless of how many cells I select from the scan table.
    I am a new user of HP Tuners, but I can only assume that it would be appropriate to target specific cells without skewing the entire table.
    I'm running v4.4.4 for my scanner and editor.
    Computer is Windows 10 x64.
    I am tuning a 6.0 Gen III with a P59 PCM.
    This is the scan table and specific cells that I am trying to grab.
    VE Table before paste
    VE Table After paste
    Aug 2018
    293
    Yeah, it won't work that way unfortunately. I always just put it into excel, and delete the cells you don't want to change. Then copy that table and paste it into HPT so it only writes the cells you require.
    Aug 2018
    13
    Thanks for the reply.
    I feel like in previous version that it did work that way, but I might be wrong. And as I mentioned, it will work that way intermittently.
    I've only been working with this program for about a year, and it sure would be a good time saver to be able to cherry pick the cells.
    Jan 2020
    1
    Quote Originally Posted by RobZL1 View Post
    Yeah, it won't work that way unfortunately. I always just put it into excel, and delete the cells you don't want to change. Then copy that table and paste it into HPT so it only writes the cells you require. run 3
    Thanks for your answer. It helped me a lot.
