Results 1 to 3 of 3
Thread: 6r80 shifting issues
    Jul 2019
    6
    I have a 2015 f150 coyote and 6r80 trans swapped into a 70 f100. Ive got it running and driving but it shifts terribly. First thing I've noticed is the vehicle speed is not reading it always says 0. I checked the the harness and connectors they are fine. My question is.. Is there a setting I can change with hp tuners to get that working. I would think that has to be reading to shift properly.
    Jun 2016
    42
    Shifts in 15+ F150's are based off of OSS speed and pedal position. Vehicle speed, which comes form the ABS module is used as a logic check as well. YOu have to have both OSS speed and vehicle speed input into the PCM for the transmission to function properly.
    Jul 2019
    6
    Quote Originally Posted by OzTuning View Post
    Thank you for the response Does this mean if I am not using the abs module I will not get the ecu to see vehicle speed. I don't care about getting a speedo to work I am wondering if vehicle speed doesn't show is that affecting the tran shifting etc..
