Results 1 to 6 of 6
Thread: Boost segment swap
    Boost segment swap
    If boosting a lt1 Camaro can a segment swap be done with a zl1 file that has the same OS number? The segment swapper seems to allow these two particular files to swap. I believe this would be beneficial to start with a zl1 file after adding a lt4 blower
    28,265
    can you? Probably. Should you? Probably not. Will it cause more issues than it fixes? Maybe.
    Personally I wouldn't willy nilly be segment swapping just to save some time.
    Aug 2009
    Calibrating
    3,373
    Not even an option, just use factory controls and tunes just fine
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Aug 2009
    Calibrating
    3,373
    DONT START with a z06 or ZL1 file, NOT a good place to start
    14 Gen 5 Viper
    Aug 2014
    Central, LA
    737
    Starting with lt4 data on an lt1 is a good way for your lt1 ringlands to leave the building.
    I meant a starting point as a file not to start the engine. I would change the timing and fueling maps/tables etc before firing it up. It was not to save time or knowledge of where to start. I wasnt sure if there were minor differences to other relatively insignificant tables may add up to making run differently under certain conditions. Obviously there are plenty of boosted lt1s running excellent making changes to the current file
