Results 1 to 14 of 14
Thread: 2018 Camaro manual stock file
    Sep 2019
    19
    Hi all,
    do somebody have a US stock file from a 2018 Camaro 2SS with manual transmission and could probably post it here?
    I need to do a swap but thats not possible with the file from repository.
    My OS is 12688025
    Thank you
    Oct 2013
    211
    stock (5).hpt
    This is a 2017, not sure if it helps
    Sep 2019
    19
    Quote Originally Posted by ZincGT View Post
    stock (5).hpt
    Didn't helped. It has OS 12678648 instead of 12688025. Thanks anyway
    2018 Camaro SS headers only (Rev 0).hpt
    your in luck, heres a stock file you need.
    Roger
    Sep 2019
    19
    Quote Originally Posted by regorih View Post
    Roger
    Thank you. Is this a manual? I ask because the car doesn’t start. It’s like it doesn’t recognize the clutch.
    what swap are you doing?
    Sep 2019
    19
    On my own car (EU Camaro 2018 automatic transmission) I did only a system swap to get rid of the 3rd gear problem.
    https://forum.hptuners.com/showthrea...esponse-in-3rd
    Now I wanted to do this to a friends car who have the same model but with manual transmission.
    So I have to do a system swap with an US model.
    I found 2 files. One manual (in repository) but with other OS. So I’m not able to do a system swap.
    And yours. But I don’t know if this is a manual transmission.
    But when I do the system swap with your file then the car won’t start.
    Sep 2018
    This should be what you are looking for.
    Sep 2019
    19
    worked. thanks
    Jun 2023
    7
    Hi,
    I hope someone can help us. It goes to this topic with the 3rd gear and OS Swap.
    We bought a used 2018 EU AT Camaro and wanted to disable the AFM and 3rd Gear Torque reducution.
    Now we saw that some items aren't there were they should be. Checking the OS it looks like someone did swap the OS to get the 3rd gear torque disabled with a different OS.
    The OS loaded (12686391) looks like one from a ZL1, where we have an SS. (can someone confirm?)
    The OS which should be on the car is 12688025 (compared with my 2018 AT Conv. and a stock file shared here in the Forum from zr1driver).
    How could we now get the correct OS on the car again?
    Just load a stock file (write entire) ? I thought this is not possible due to the VIN?
    Any help would really be appreciated.
    Attached a screenshot of the comparison of the Controllers screen.
    Thank you
    Jan 2023
    NY
    228
    Seems like that's the correct OS. Here's a 2018 SS stock file I have for comparison. Same OS as the ZL1 from what I can tell
    Jun 2023
    7
    Quote Originally Posted by rabbs88 View Post
    OK. strange. But this is a US Version right? Not an EU Camaro?
    Still i guess, that the OS loaded is not the correct one for the EU Version.
    How to revert it back to the EU Version ? Any idea?
    Jan 2023
    NY
    228
    Yes its a US version, not sure if they're any different. Also not sure you can even flash another OS unless it's a custom one from HP tuners? Which I don't believe there are any for Gen 5. Hopefully someone else chimes in, I'm not at my computer at the moment
    Jun 2023
    7
    thx rabbs88
    @zr1driver @robka
    Are you able to help?
