Results 1 to 3 of 3
Thread: ls1 lean at wot help
    Oct 2019
    2
    lean at wot
    is it the o2 sensors or the fuel pump ?
    stock ls1
    13,559
    You'll have to figure that out yourself.
    Get yourself a wideband o2 sensor so you can monitor the real time air fuel ratio's.
    For now you can hook up a fuel pressure gauge to the fuel rail to watch your pressure. Add more channels to your logs too. Like commanded AFR, knock retard, injector pulse width avg, cylinder airmass, a wideband o2 sensor.
    Sep 2017
    736
    O2s have nothing to do with fueling at WOT. If your adding fuel and its bot getting more rich your most likely not getting the fuel.you need.
    1997 30th SS. Torqhead 24x, TFS heads, 223/235 cam, 4l80e, S60 D1SC 14psi
