Results 1 to 6 of 6
Thread: LTFT what and where? V8 gen4
    Dec 2019
    2
    I figured I should label it "that new guy" question. My ltft is -12 to -8. I've searched and have tried to find where I need to change this at and one thread said at the "main ve, primary ve vs. Blaw blaw blaw..... I'm not seeing it! I've looked through my editor and just not seeing it. If it is not right where or what do I change? This is a tune gone wrong by a local "tuner" and I've taken it on myself to fix it and it's good but this issue. PLEASE HELP!
    Nov 2009
    All Around
    3,149
    you could be in Basic view under options
    Dec 2011
    San Antonio, TX
    319
    if you're working with gen4 you probably don't have a traditional VE table, its likely VVE. If its a VVE vehicle it's likely being run MAF only, and that's where you need to make sure changes (the MAF table)
    JTC Performance - Authorized HP Tuners Reseller
    Remote performance tuning
    Dec 2019
    2
    Thank you for the replies! I've checked and it is in advance view. It's a 2007 chevy avalanche with 5.3 afm delete and tsp stage 4 truck cam 111 lsa. I didn't see anything showing vve just ve. I will check the maf.
    Aug 2018
    294
    VVE is under the "edit" menu up top. Do some reading on VVE to understand how it works- it's pretty cool once you understand it. As noted, though- it's very likely your current tune is MAF-only. If you're new, I'd keep it MAF-only for a while and learn that first. Then venture into VVE later if you'd like, to help with driveability of that big cam.
    13,565
    Get a wideband o2 sensor.
    I wouldn't even bother with fuel trims on a camshaft that size. Trims can be fixed/cleaned up once the MAF/VVE are done with the wideband.
