Results 1 to 6 of 6
Thread: 2012 Challenger over boost shutdown P0108
    Has anyone been able to get their Challenger to boost beyond 195kpa without the car shutting down on them? We lose throttle when this happens. We cannot raise max map in Engine Diag or else the problem will get worse. I believe this has been talked about before but no solution was brought to light. Possibly a table I need to request to be defined? Watch in the log as the Pratio, map, map(SAE), and the map voltage go haywire the instant the map reading steps past the 195kpa limit which we are limited to. About 4:27 into the log.
    Advanced Tuner coanan's Avatar
    Mar 2009
    S. Florida
    582
    Quote Originally Posted by drumnbasslvr View Post
    Start at post 7
    https://forum.hptuners.com/showthrea...h-supercharger
    2018 Trackhawk PCM/TCM tune by Dusterhoff.
    Flex Fuel, MMX faux 95mm TB, GripTec 2.85, 10% ATI lower, FIC1200, ARH 1 7/8 w/cats, 180 T-stat
    13 Chrysler 300S, RAM BGE 412 stroker, cam motion 232/246 619/619 118 +4, ATI 18% OD pulley
    Whipple Gen5 3.0, 2.50 upper pulley, Smooth Boost controller, FIC 1200 inj. Nick W 108mm TB, FORE dual return fuel system, E85, FTI 2800 stall(SRT83380), SHR WAR Viking trans and valve body, Getrag 3.73, 1 7/8 kooks w/hi-flow cats, 3" Magnaflow Cat-back 943rwhp
    Thank You! Yes a 3 bar map sensor is a solid answer for now. We are pegged at 195 kpa yet still but no shut downs occurred. The map sensor voltage is tamed to the range of 3.8 volts at wot now in a long pull.
    Mar 2009
    S. Florida
    582
    Good to hear you're moving forward. Remember to come back and share if you can add some knowledge.
    Oct 2019
    ATL
    55
    What MAP Sensor Linear value and MAP Sensor Offset value did you use with the 3 Bar MAP sensor?
    Oct 2019
    ATL
    55
    you download an SRT4 tune from the repository...... and look at the Linear Value and Offset to get the values to use with the 3 Bar MAP sensor.
