Thread: Looking for IAT sensor calibration after Eforce install
    Nov 2018
    3
    Recently had a pre-owned Eforce supercharger installed on my 2009 Silverado. When i wanted to install a vac/boost gauge, I found that there was an IAT sensor where the boost gauge would normally go. I re-wired the TMAP harness to read IAT from the TMAP sensor, but it appears I need to re calibrate the IAT parameters. (keep getting a P0113 code and it thinks IAT is -40F)
    I have a custom tune from the shop that did the installation and VCM editor 4.4.4 for tinkering and basic tweaking. I would like to calibrate the IAT to run off the TMAP, but when i go to Airflow tab, all that's available is MAP and MAF calibration. (IAT sensor is not there)
    Any ideas
    Aug 2018
    292
    Edit > View > Advanced
    Nov 2018
    3
    Thanks!
    Nov 2019
    Did you ever find a tune for your eforce? I'm in the same jamb you were in.
