My MPVi2 is 4months old and it has intermittently had difficulty connecting to the PCM, the PC appears to connect to the interface but will not write to the pcm or operate the scanner, disconnect it until it cools then it works.
My question is has anybody else experienced this problem?
The interface seems to be quiet warm when operating much warmer than the MPVI. The problem is intermittent and appears to be heat related because if you wait till it cools down it works. I measured the cold interface temperature at room temperature of 77 deg F.... after it has been operating (connected to a pcm and laptop) for say 30 minutes the temperature of the interface is 95 deg F can anybody tell me if this is normal?
Thanks in advance
