Results 1 to 4 of 4
Thread: 6.0 rattling
    Aug 2019
    Cincinnati, Ohio
    11
    6.0 rattling
    my dads 2001 pickup 6.0L will not run correctly with maf pluged in if we unplug it runs fin it also has a rattling only when you accelerate between 2000-3200 rpms i have tried changing everything i can think off nothing has been done to its a complete stock engine any help is greatly appreciate and any advice to check on something is also
    here is both the drive and tune that i put in today
    ne tune 12-2-19.hpt
    drive 12-7-19 rattles 2000 to 3000 rmps.hpl
    13,559
    Look at your fuel trims man, they are pegged at +25%.
    You have a major issue there. Be is very bad vacuum leak, bad exhaust leak or low fuel pressure.
    The log shows heavy amount of spark knock, maybe it's possible you are able to hear this. Part of this issue is carrying over into PE because the computer is adding in even more fuel as the injector duty cycle is going through the roof. A stock 6.0 should be only touching something around 80-90% max.
    You aren't helping the knock issue by mirroring the timing curves either, it can't pull timing if both tables are the same.
    Aug 2019
    Cincinnati, Ohio
    11
    so we found the the problem the flywheel was broke which was causing it to pick the knock up
    13,559
    Still try to figure out that lean condition though. The flex plate issue was a separate thing for sure.
