Results 1 to 20 of 22
Thread: 08 silverado 5.3 turbo help
    Jun 2016
    12
    son installed 98mm turbo removed mass put iat in tube and 2 bar map with 80 pound injectors this is all new to me have only made small adjustments to the computers i have accessed this thing will start but will not idle long he has done everything in tune seems lost it is in reduced power need out of garage but not exactly where to start any help greatly appreciated
    13,557
    Gotta post the tune to get any help.
    Jun 2016
    12
    i dont know how to get it on here
    13,557
    Click the advanced reply box, then there should be an icon for linking attachments to your posts.
    Jun 2016
    12
    file:///C:/Users/john/Downloads/08%20silverado%20regular%20cab%20modified.hpt
    Jun 2016
    12
    i hope that is it
    13,557
    Nope, that didn't work.
    Jun 2016
    12
    i have got it started but cant get it to idle i can give it gas and keep it running
    Jun 2016
    12
    also im using a 3 bar map with the 2 bar os
    Mar 2011
    Ripley, MS
    1,865
    The 07-08 E38's have a max injector flowrate limit of 63.5 lb/hr. The easiest way to work around this is to scale the injector and AF ratio tables.
    Double the stoich and half the IFR.
    I did that for you here. Give it a try and see how it performs.
    Edit...Oopsy! I just saw what I did on the IVT terms. It's fixed now.
    08 silverado regular cab kw modified.hpt
    13,557
    Why did you double his IVT terms?
    You need to half the IVT terms when doubling the stoich.
    Mar 2011
    Ripley, MS
    1,865
    Oopsy! You're exactly right. It's fixed now...
    Thanks!
    Jun 2016
    12
    thanks for the help im having issue with idleing the tune i used was for a cam and myn is stock
    Jun 2016
    12
    i made the adjustments and now it doesnt want to run or idle
    Mar 2011
    Ripley, MS
    1,865
    Exactly what injectors are you using?
    Mar 2011
    Ripley, MS
    1,865
    Try this.
    The VE numbers were pretty low at idle. I increased them to get them closer to a stock table.
    08 silverado regular cab kw modified plus20% fuel.hpt
    Jun 2016
    12
    80lb 840cc siemens deka ev1 i have adapters for ev6 to ev1
    Jun 2016
    12
    i tried that and it did help some it just seems like its not getting enough fuel i dont understand when i had the injectors turned up they did better it idle and i could drive it but right now it wont move
    Mar 2011
    Ripley, MS
    1,865
    Quote Originally Posted by johng View Post
    Try this and do a datalog. Let's see what the short term fuel trims are doing.
    08 silverado regular cab kw modified plus36% fuel.hpt
