Results 1 to 7 of 7
Thread: p0171 p0174 2007 corvette
    Dec 2019
    4
    I am throwing p0171 and p0174 codes. Cannot seem to find a vacuum leak, fuel pressure seems okay. Any ideas what could be wrong? Car has long tube headers, no cats and an aftermarket intake. Here is a log of driving the car. Lemme know what you think and what you need from me to know more. Thanks in advance.
    13,533
    Did you check fuel pressure with a manual gauge?
    The channel you are logging for fuel pressure never moves, perhaps that channel does not work as there is no real pressure sensor on this vehicle.
    Dec 2019
    4
    It has a fuel pressure gauge "built in". Reads from 40-60psi as driven
    13,533
    What else can you say about this vehicle?
    Did the problem happen out of the blue?
    Did you just install these mods and the car hasn't been tuned yet?
    Did you smoke test the intake and exhaust for air leaks?
    Dec 2019
    4
    Yes, 100% out of the blue. Intake and exhaust checked. It's almost as if the codes are fake. 50% of the time the car runs perfectly like it is brand new and then throttle blip and stumble when codes are thrown.
    Jan 2019
    White Hall, Arkansas
    73
    Probably wouldn't hurt to check your connections at the MAF sensor. This looks like a good time to invest in a wideband if you don't already have one. Something's obviously not reading right.
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    Check the ground for the fuel pump. Notoriously famous for being loose
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
