Results 1 to 10 of 10
Thread: 5.3 turbo start up tune
    Feb 2017
    12
    Hi guys,
    I'm new to boosted motors and I'm wondering if any experts can look at my start up/idle tune/log and provide some feedback. It's a 3 bar SD setup. T76 turbo, 224/224 cam with 110lsa, 4l60e (I will most likely do a 4l80 soon), 80# decapped injectors.
    I'm curious about kPa at idle and vacuum. i setup a boost/vacuum gauge and i'm seeing -9.30 for vacuum at idle. And it's lean, which I'll work on. I know I need to work on VE tuning and spark, but i'm just making sure I'm off to a decent start.
    Appreciate any comments or thoughts you have.
    13,576
    What MAP are you using?
    Your map kpa on key on and when you shut it off is rather high at 105-106kpa. It should match where you live. Like 100kpa key on engine off would be at around sea level.
    Feb 2017
    12
    It's an LS1 style 3 bar MAP from EFI source.
    Feb 2020
    14
    Any other insight on this? My truck runs perfectly, but my gauge is seeing about 11psi boost, but my MAP is seeing about 6 ish (140kpa)
    My idle is about 70kpa also with a Sloppy stage 2
    hard 1-2.hpl
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    sounds like maybe a Chinese knockoff MAP sensor was used instead of a GM unit... or the scaling is wrong... or both.
    Steve Williams
    TunedbyFrost.com
    Feb 2020
    14
    I sorta had the same thoughts, but I bought this from EFI source, the truck 3 bar map.
    Jan 2006
    Richmond VA
    1,950
    Yeah, it's exactly what I said it would be... a Chinese / non-GM unit. When a legit, GM, ZL1 MAP sensor is under $40, there's just no excuse for using junk like this. There's places to save a $ and places where you should never. Although de-capped injectors are being discussed in this thread, so it's likely my feedback will be lost lol.
    Steve Williams
    TunedbyFrost.com
    Feb 2020
    14
    Huh, I thought I was getting a tested and true unit because I didn't want to run into this shit. I thought EFI source was reputable.
    Feb 2020
    14
    OK you got me for a sensor and harness adapter.
    These look correct?
    linear 312.50
    offset -11.25
    See if I can smash this thing on a truck manifold somehow.
