2007 hemi turbo 3 bar setup
Is it normal that after I have updated my map linear and offset I don't have anything above 107 kPa on my timing map, or did I miss something? How is it going to know when to start to pull timing under boost? I'm confused that the rest of the maps don't automatically change the scale. Any help would be appreciated thanks.
You can right click and choose edit row axis to re-scale the labels. Some of the PCMs have a hard limit of - I think 195kpa? If that is the case, you will just have to deal with it and figure out where you are in the map using a graph while ignoring the labels.
Awesome I kind of thought that might be the case thanks again
If you need help setting it up I can help you out
post your tune, you will need to enabled Sensed Map
