Results 1 to 8 of 8
Thread: TCM Programing (new to HP Tuners please help)
    If I copy a tcm file on a 2015 chevy truck before I remove the transmission. Install a new gm transmission. Can i write the file to the new transmission? Basically can I program a new transmission to a 2015 Chevrolet truck?
    Advanced Tuner 2therock's Avatar
    Jun 2009
    N. GA
    530
    I haven't worked on a new model GM but as far as I know the TCM is not on the trans.
    2013 Dodge Charger R/T Plus, Stock 5.7L, Edelbrock E-Force Stage 1, 3.25" Pulley, 450-HP 459-TQ.
    Corsa Sport CatBack, 3.06:1 Wavetrac, Dual Fans, 1-7/16 Radiator, Mopar Oil Cooler
    2005 Radix'd Silverado L33 5.3 ECSB Z71 @ 387-HP 395-TQ
    yes sir it is in the trans on 6l80E. if you swap one out you'll have to get it programed or flashed before it will shift. looks to me like if you can recalibrate the tcm's program you should be able to put the same program in a new one. I still like my hp tuner but damn they suck with help, directions, etc.
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    HPTUNERS WILL NOT PROGRAM A BLANK TCM, ALSO HPTUNERS DOES NOT WRITE EVERYTHING FROM THE FILE, ONLY SPECIFIC CALIBRATION PORTIONS. ANYTIME YOU INSTALL A NEW TCM, ESPECIALLY OF UNKNOWN ORIGIN i WOULD FLASH IT WITH A FACTORY FILE, THEN LOAD YOUR SETTINGS BACK IN
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Aug 2022
    4
    Where can I get a factory file to flash it? And flash it through HP Tuners, or does it have to be done using another program? I just ran in to this issue. Any help would be greatly appreciated.
    Jul 2020
    VIC Australia
    1,160
    You MUST use sps2 with a mdi2 or clone. After that is done you can tune with HP.
    Aug 2022
    4
    Thank, really appreciate it. Also appreciate the quick response.
    yeah Goatrope garage on yt, discusses the md12 clone and flashing techm
    or a gm dealer can do it,
