Results 1 to 8 of 8
Thread: 08 Mustang engine trans swap Bcm code deletes?
    Dec 2012
    235
    Hello, this might not be supported it seems. But I have a vehicle with 08 Mustang engine/trans swap. He used everything from the Mustang, gauge cluster, fuel pump etc. The only problem is the gauge cluster is showing all the body codes, i.e. abs, door ajar, tire pressure sensors, etc. This swap is in an old 53 Ford pu, so obviously it doesn't have tire pressure, door pins, abs sensors etc. Is there any way to acces the Bcm to shunt these codes?
    Forscan can do it although you need to wire in at least one door switch so the cluster and bcm will properly shutdown, or else they will stay on for 10-15 minutes after the key is off
    Dec 2012
    235
    Ok, Thank you. I will try Forscan and have him wire in a door switch. I appreciate your help!
    Dec 2012
    235
    Quote Originally Posted by crash01 View Post
    Does Forscan allow you to flash the Bcm? Or does it just allow you to clear codes? I would need to delete, or shunt the Bcm codes that are coming up.
    Mar 2019
    351
    Forscan will allow you to make changes to the BCM programming.
    Dec 2012
    235
    Ok, do I need an interface software? I messaged Forscan, and they didn't seem to think I could reprogram the Bcm. Thanks for the input.
    Mar 2019
    351
    Their forum will be a better resource to get your questions answered https://forscan.org/forum/
    Dec 2012
    235
    Thank you. I will go check that out.
