Results 1 to 4 of 4
Thread: Help with stall issue after MAFLESS - Gen 4 L98 VCM 11, VCM OTR, 6L80e
    Tuner in Training dion.climo@renova.co.nz's Avatar
    Mar 2019
    New Zealand
    15
    Angry Help with stall issue after MAFLESS - Gen 4 L98 VCM 11, VCM OTR, 6L80e
    Hi all,
    I've recently went to a MAFless tune on my 07 VE SS but cant solve a stalling issue. Has run fine on the MAF tune for over a year but now it stalls with more than a tiny amount of throttle when you first put it in gear. If you let her roll in D or R and get some momentum before throttling-up it pulls nicely but stalls when you come to a stop if you don't shift to neutral (usually lol). Revs clean and crisp across the RPM range.
    Initially she wouldn't idle at all so after several unsuccessful writes we solved that with a hole in the butterfly.
    This tune is built from from an identical car that runs fine with a healthy 356kw at the hubs.
    Attached is the last MAFless file and any help/thoughts that can prevent me losing what little hair I have left would be much appreciated
    What have I missed?
    12Dec_MAFLESS_TUNE_stalls.hpt
    Cheers,
    Dion
    Depending on the size of the hole you put in the throttle body, you will need to add some airflow to your base idle airflow table.
    Also will need to add some timing to your base idle spark table.
    Make sure your fuel trims are in the ballpark as well.
    Nov 2009
    All Around
    3,149
    add a log please
    max out your "Max Fail" under Effective Area under Idle -> Airflow. Also maf isn't failed correctly
