Results 1 to 2 of 2
Thread: Can HPTuners be used to overwrite settings to return a flashed computer back to stock
    Can HPTuners be used to overwrite settings to return a DimSport or Renntech flash to stock assuming you have the factory parameters from a similar ECU? From what I've found through online archive of other manufacturers yes, but not sure if this will also be possible with Mercedes.
    Bill was able to respond to my question.
    You should not be using HP Tuners as an OEM flashing device on ANY application. We always recommend using an actual OEM style device in order to flash an ecm to stock, any other way is not recommended.
    Additionally, no, we do not offer write entire for every application we support making it not possible on many applications to even try to use it as an oem device.
