Results 1 to 6 of 6
Thread: Issues seeing data for pids
    WONDERING IF ANYONE CAN HELP MY SCANNER IS NOT READING RPM OR MAP AND MAF ALONG WITH KR ANY ADVICE GUYS?
    IM NOT SURE WHEN IT HAPPENED BUT I AM THINKING AFTER AN UPDATE. I noticed its not operating with 07 nnbs and up models.
    scanner
    Attachment 95424 this is my current scanner layout if you guys can try it out and let me know
    13,578
    Best thing to do is to remove the channels in question. Then re-poll for supported parameters under the vehicle tab while connected to the vehicle. Then go back and add those specific channels to the main channels list.
    See if that does anything for you.
    Jun 2014
    13
    I had the same issue with my scanner. I did what you suggested and got everything back but AFR (reported from wideband). Added the channel from Serial Port > AEM > AEM- AFR. When I click the red dot to log, AFR disappears from the left hand list of monitored data. Any thoughts?
    Repoll seems to help Thanks guys
    Senior Tuner 10_SS's Avatar
    Mar 2012
    Detroit, MI
    1,320
    repoll usually always works for me. If that doesn't work, then re-add channels.
    ZL1 Wheels/Tires
