Results 1 to 5 of 5
Thread: C7 LT1 Texas Speed Stage 3 cam 32% fuel lobe base tune / impact on ODB emission test
    Hello,
    First question : I'm going to install and tune myself a stage 3 cam from Texas Speed 235/239 0.645"/0.635" 116 LSA on my C7 GS M7
    Car already has ARH LT headers, Catted X pipe, MSD intake manifold, Ported TB, AFE CAI with a tune I did myself.
    Does one of you has a tune for a similar setup I could base mine of, or at least a startup tune I could use ?
    I'm going to order the parts next week, but I would like to study how different the tune could be from my current bolts on tune.
    A second question : My state (Idaho) has a basic emission test through ODB. Will I be able to pass in your opinion, knowing they just plug on ODB and scan for emission codes...
    My concern is the idle lope which will probably mess up lambda values ? Was thinking of possibly raising the idle for the test... I think the idle test fails they test at 2500 rpm...
    Thanks in advance
    311
    Well no expert but I'll give you what I've experienced. I have a L86 sierra so basically the same motor. I installed a smaller TSP VVT2 cam 218/226 .635/.635 32% fuel lobe. It's smaller because I tow a lot and I wanted to keep the stock stall. It will need a tune because it will through a check engine light and that will cause it to not pass inspection. Watch Goat Rope Garage tuning series, He has the best GEV 5 tuning stuff on youtube.
    https://www.youtube.com/channel/UCP_...JqJOiGoCRT5SCw
    I just had mine inspected yesterday and our laws are similar to yours. I had no problem, as long as your not throwing a check engine light you'll be fine.
    Nov 2009
    All Around
    3,149
    best to post your tune and log when your done with install
    Quote Originally Posted by Jonblarc7 View Post
    Yep I saw this channel few days ago and there is good insight for tuning the idle with a cam
    Apr 2007
    330
    Did you ever find a tune to start with? I am in the same situation and am in the process of installing a TSP Stage 1/2 cam in my LT1 Camaro.
