Correct, 114-120 LSA is best range for positive displacement supercharger, 104-108 for Procharge/vortech types, You also need more lift and duration on the exhaust side to aid scavenging along with wider lobe separation to reduce valve overlap, long overlaps the intake charge goes out the exhaust valve, . like you mentioned , ..
It is a fine line between valve overlap and exhaust lift and duration. and those TSP cams have over the competition(at this point ) is more Exhaust lift and 5* more duration and are in the sweet spot of LSA which helps these G3s, the best Exhaust flowing ports in theses G3s is still less then 75 % intake to exhaust ratio, the 120+ LSA are great for emissions.but the G3 hemi doesn't act like a act like a Traditional Hemi(which a lot of the early G3 aftermarket cams were designed after) during the early rotation after BDC intake stroke, we don't need to close the exhaust valve as early,. .. keep in mind that a traditional G2 hemi the valve angles are Intake 35*; exhaust 23*, the G3 it's 18* for both, and the intake path is as close to a straight downward angle as you can get, point is the Intake charge is pushed down in to the chamber, and not into the exhaust valve, this allows the G3 to utilize smaller LSA's , the nature of the 18* angle draws on the incoming intake but doesn't pull on it like the older Hemis.........which is also why we need to close the Intake valve as fast as possible because of it's angle it's more prove to intake reversion.
........in four different cars,on 4 different chassis dyno's and 6 different track rentals here in the mid Atlantic, I've seen those TSP cams run 40-60hp better on the chassis dyno and on the track 3-6 tenths faster than both the Hellcat and Demon cams.........for the record I am not affiliated with TSP and you couldn't give me one of their NA cams.
