Results 1 to 7 of 7
Thread: Tune help please
    Sep 2018
    4
    Tune help please
    Taking my first swipe at this project. 2000 5.3/P01 ECM. Cannot get a steady idle, seems like a vacuum leak but engine passed a smoke test. I turned off alot of tables to simplify but ......TIA
    Sep 2018
    4
    Set up is: E85...160 lb. FIC injectors. Dual AEM fuel pumps.. BW twin 64.5 turbos..Tooley stage 3 cam 230/235 duration. Stock truck intake and TB.
    Sep 2018
    4
    Log file
    Here is a short log file....needed a little throttle to keep it running
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,455
    Go to Engine diagnostics--Airflow-- and zero out the MAF. Don't know if that is the problem. Where is your wideband iput? Your map should read 100kpa at key on engine off. Looks like it reads 50 ??
    2013 Silverado 5.3, 6L80k 8.8
    May 2018
    Milwaukee, WI
    38
    Agree with Lakegoat. In addition what MAP sensor are you running? Looks like your scanner setup is still at 1bar. May also need to change Min Fuel Milligrams in Transient Tab to a lower number with those injectors.
    Sep 2018
    4
    Thanks for the replies....I am new to this...LOL... I will follow up on what you have posted. Thanks again..
    Check out my videos on tuning. Might help you navigate this a little better. Link is in my signature.
