Page 1 of 3 123 LastLast
Results 1 to 20 of 50
Thread: Sluggish O2 sensors
    Advanced Tuner Ghostnotes's Avatar
    Feb 2012
    Houston, TX
    471
    Sluggish O2 sensors
    I travel a lot and and only get a little time to do yard work honey do lists and car work. One thing I have noticed is that my O2 sensors are sluggish. The trims are good +/- 2%-5%. I know one of the reasons is because the sensors sit further back since I have longtubes. I also read somewhere, I think it was Higgs is that you could set your milliamp voltage slightly different to help, but looking at the tables in Engine>Oxygen sensors> Integral delay there is also an amount of time to declare a rich/lean switch condition. Is it feasable to shorten the period? The logic would seem that you can adjust the voltage to declare how much mV, and then how much time it would require to se it before switching?
    Or would this cause other problems?
    I always tune VVE....
    2016 C7 M7 Z51
    Callies ultra billet crank
    Callies ultra billet rods
    Diamond pistons
    Jhonson high speed lifters
    Ported and polished headwork
    Custom cam
    YSi-V7
    Mar 2010
    Texas Hill Country
    3,299
    this probably sounds funny, but I run all my personal cars full time open loop and ditch the factory narrowbands. I have three widebands in my Z06, lol.
    Once tuned, none of my cars deviate more than 5% from commanded throughout a whole calendar year.
    Feb 2012
    Houston, TX
    471
    Quote Originally Posted by Higgs Boson View Post
    As long as you dont move from Texas to say Denver, if its dialed in.......
    2016 C7 M7 Z51
    Diamond pistons
    Custom cam
    YSi-V7
    Feb 2012
    Houston, TX
    471
    Here's what I'm talking about...
    I'm showing some torque advance still, so I need to figure out which way to go with my torque settings. That I hope will settle my timing advance some more.
    Or is that because I'm running a large cam?
    2016 C7 M7 Z51
    Diamond pistons
    Custom cam
    YSi-V7
    Dec 2015
    Miami,Fl.
    290
    Are you still running stock o2 settings?
    2023 Ford Maverick 2.0T AWD
    Feb 2012
    Houston, TX
    471
    Yes I am
    2016 C7 M7 Z51
    Diamond pistons
    Custom cam
    YSi-V7
    Dec 2015
    Miami,Fl.
    290
    Gotta slow them down some for those long tubes like I did.
    May 2003
    South FL
    1,375
    Set the O2 mv's swing to 450/450 instead of 550/350. This will waken them up a little bit. Common change when doing long tubes. It shouldn't change the max/min fuel trims observed in the scanner, but it should make the low throttle and idle trims react quicker.
    [email protected]
    Owner/GM Calibrator
    Feb 2012
    Houston, TX
    471
    Ok it was you not Higgs.
    That worked and I did shorten the declared time and they are a perfect sinewave now with +/- 2%. Lambda is a lot more steady and only swings from .98/1.02 realtime...not avg.
    I still have about 3-4* torque advance i need to work out at idle.
    Thanks guys!
    2016 C7 M7 Z51
    Diamond pistons
    Custom cam
    YSi-V7
    Dec 2015
    Miami,Fl.
    290
    What do you mean you shortened the declared time? The Integral Delay> Airflow mode?
    Feb 2012
    Houston, TX
    471
    Quote Originally Posted by HeavyChevy305 View Post
    Thats it.
    2016 C7 M7 Z51
    Diamond pistons
    Custom cam
    YSi-V7
    May 2003
    South FL
    1,375
    Quote Originally Posted by Ghostnotes View Post
    Thanks guys!
    Torque Management Advance is normal at idle. Do you only have 3-4 degrees total TMA? Or are you saying you would like to see 3-4 degrees less of TMA at idle?
    A quick way to reduce TMA at idle is to lower the virtual torque tables in the idle area.
    [email protected]
    Owner/GM Calibrator
    Dec 2015
    Miami,Fl.
    290
    Thats it.
    If anything, you're suppose to increase the delay time.
    Dec 2019
    MS
    567
    Ive ran a many years on the same Open Loop tune with a Turbo LQ4 towing. Never seen much of a difference. Just kill engine while fueling up and let it get a fresh Baro Reading at startup seems to make a difference if altitude changes.
    May 2003
    South FL
    1,375
    I'm referring to Fuel>Oxygen Sensors>Rich/Lean vs Airflow>Max Rich and Max Lean. Set these to 450mv.
    [email protected]
    Owner/GM Calibrator
    Dec 2015
    Miami,Fl.
    290
    What got mine reading accurately was decreasing Proportional>Airflow Mode by 10% and increasing Integral Delay>Airflow Mode by 15%.
    Feb 2012
    Houston, TX
    471
    I tried that and they would hang for too long and my WB swung wider. Now my WB is .98-1.02 again. Before it would swing from .95-1.08.
    2016 C7 M7 Z51
    Diamond pistons
    Custom cam
    YSi-V7
    Feb 2012
    Houston, TX
    471
    It's at about 10* ish right now.
    I was scanning a friends last week.....bone stick with around 15 to 18 warm...
    2016 C7 M7 Z51
    Diamond pistons
    Custom cam
    YSi-V7
    May 2003
    South FL
    1,375
    With a larger cam, your idle cells are all different in the VVE and VT tables vs airflow. You likely need to reduce the VVE in the new idle areas and even the VT.
    [email protected]
    Owner/GM Calibrator
    Feb 2012
    Houston, TX
    471
    Thanks,
    I had some local person say just the opposite saying it was adding because i was not producing enough.
    2016 C7 M7 Z51
    Diamond pistons
    Custom cam
    YSi-V7
