I am having an issue that I have never come across that has me stumped. LS Swap into a square body. Truck starts and idles perfect. Does great shifting into drive and reverse (no stumbling). Can foot brake the truck over 3k in drive or reverse without it cutting out. Here is the problem, as soon as the truck is moving forward or reverse it will accelerate normally for a few seconds and then fall on it's face (but will not die). It will pick up after a few seconds and start to run again for several more seconds then do it again. If your moving fast enough between it cutting out and picking back up it will shift into the next gear without an issue but will again cut out and recover (over and over). I have attempted to drive it in only first gear and it does the same thing.
I have changed the PRNDL settings to all 3 options hoping that would do something but it does not change anything.
I have also checked the TAC module and pedal and all is good there.
Something is sending a signal that is causing to cut out while moving but I am lost at this point. I'm sure it's something someone else has run across and is probably minor. Any help at all would be great, I should have had this running months ago.
Motor and trans info: 2001 suburban with 4L60 with factor 411 ECM. Motor is stock except for shorty headers and the emissions removed. Has new MAF and MAP. It is a drive by wire.
