Results 1 to 6 of 6
Thread: LS3, E38 ecu , whipple install.
    Jun 2019
    9
    2015 SS camaro, LS3 , whipple with stock 4.0 pulley, LT headers no cats, LS9 cam. What would be the general consensus on manifold volume settings for this setup to aid in transients?
    All help appreciated.
    Aug 2009
    Calibrating
    3,373
    10.5-11.5 (depending on how big the “snout” is) be a solid foundation
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Apr 2016
    331
    I assume that is for the 2.9L front feed Whipple? Haven’t played around with this setting for awhile but did so with the rear feed 2.3L Whipple. Stock truck manifold was 14,000, but so were some stock cals for factory blown cars. I lowered it some but can’t remember where I ended up.
    Jun 2019
    9
    Ben Charles, stock ls3 is 9540cm so your saying about 10-20 percent more over stock as a
    trial to start out, up to 10,500-11,500 cm?
    Jun 2019
    9
    Whipple snout on 2.9 blower I believe is tapered to 93mm
    Jul 2019
    Baytown, TX
    118
    Mine is set at 13500cm^3 with same mods (except no cam).
    2016 Chevy SS Sedan M6 SBE LS3, Whipple 2.9L, 3.625 upper/stock lower pulleys for 9.5psi, TSP Stg 3 SC Cam, ID 1050x injectors, LS7 MAF, DSX Aux Pump, DSX Flex Fuel Sensor
    2009 Dodge Challenger SRT8, 6.1 HEMI, Edelbrock E-Force TVS-2300, 9psi
