Results 1 to 16 of 16
Thread: Stock Tune
    Aug 2019
    16
    Stock Tune
    Greetings all, Just picked up a 2008 Silverado 5.3 WITH Flex Fuel and AFM. The previous owner had a buddy delete the AFM and changed some other things and messed it up big time. Would some one have a stock tune for this vehicle that i can compare and get things back in check.
    Thanks in advance!!!
    13,533
    Log into your customer page. I believe in the devices section there should be a tune repository, see if there is a stock file located in there.
    Mar 2011
    Ripley, MS
    1,865
    Here ya go. I'd use the compare function and just change the parameters that are different from stock.
    2008silverado53Lcrewcabstock.hpt
    Aug 2019
    16
    ok will have a look, Thanks!!
    Aug 2018
    1
    Thanks 5FDP, have been looking for this.
    405
    2,287
    There is no one single calibration for a 2008 Silverado 5.3 WITH Flex Fuel and AFM. There are going to be multiple calibrations for that year vehicle because of differences in how they are optioned. Post your VIN and I'll see if I have a correct one.
    Aug 2019
    16
    2GCEK133081320706 Thanks for your help
    Aug 2019
    16
    Quote Originally Posted by 2xLS1 View Post
    Aug 2019
    16
    So i downloaded the stock file i found that was best for my application and when i did a driving scan i noticed the AFR Command is at 12.85, and the LTFT were really rich.
    Aug 2019
    16
    Quote Originally Posted by kevin87turbot View Post
    thanks
    405
    2,287
    This one is really close. All the ECM segments match what the VIN calls for except for segment 4 which is the speedometer segment. All the TCM Segments match for what the VIN calls for. The different ECM segment 4 is probably for a different tire size. If it was for a different gear ratio there would be a difference in the TCM too.
    Aug 2019
    16
    Here is a 25 min. cruse, noticed 02 bank one seams to hang longer than bank 2, and AFR has come up some. Pulled a plug on cylinder one and sure doesn't look like it running rich lol....
    Aug 2019
    16
    Thank you 2xLS1, will compare it now
    405
    2,287
    12.85 Commanded A/F equates to around 31% alcohol content in the fuel. If you are not blending E85 with either E0 or E10, then you are experiencing the crap Virtual flex fuel alcohol content system. Happens a lot on GM Virtual FF system. It computes the % alcohol content wrong.
    Aug 2019
    16
    i see, thanks for the info
    Aug 2019
    16
    2xLS1 i compared the tunes and they are in fact the same other than small differences in the spedo category.
