2013 wrx tuning
Hello I'm wondering if anyone on here has tuned any subies with hp tuners. I used the beta software to read it and had an issue with a no start I had to disconnect from the obd2 port and disconnect the battery to get it to start it was read only no adjustments made
I haven’t tuned any but Subaru’s will do that even when you clear codes
After reading or writing in Subaru you have to open switch and wait about 20 sec before starting.
(same after disconnect battary and clear codes).
Thank you two for the quick response. It was a real scare since I had purched the car only 5 hours prior.
Does anyone know how to setup a histogram for grams per revolution over rpm to read fuel ratio
