Hi,
So I have a 2015 ZL1 and put on 1 7/8" Kooks Headers W/ No cats with an inductions Cold Air Intake. I know its been running rich and I finally was able to get an HP Tuner so I can do some logging and tuning myself with simple bolt on mods like this. I thought it was going to be easy since I spent sometime with Cobb tuning due to the old car I had but damn was I wrong. In cobb it was simple because it had the set AFR, HP, Torque and etc and all. With HP tuners it deals with KPA, and such a small increment of small numbers used for conversions and whatnot which I don't know at all. I wanna learn how to Tune it correctly. Anyways so I put below a single log I did where I have the most issues, between 00:51.319 to 01:04.236 you can see everything goes haptic. I went to drift sideways and all it does is sputter, when I get on it like a burnout or tire spin period it sputters badly as you can see. What can I do to fix it. I know I need to adjust the LTFT and STFT since they are beyond out of wack. Also how am I able to control and turn up the boost by chance if im able to?
thanks for all the help
