Hi all, thanks for reading! Just bought a Tahoe 07 4wd, 1GNFK13007R418724 with a 5.3. The shop I bought it from said the generic misfire from AFM (DOD) occurred, owner brought it in and they swapped engines. The shop seemed somewhat backwoods and didn't know much about the engine, just that it wouldn't crank whatsoever. I bought it and from running the vin, I see it had the LMG installed. I haven't broke down the new engine yet but it's an iron block 5.3, with VVT and AFM, and its a 4th gen due to the timing cover having the CPS.
Now all that's said, got it home and hooked power up (who knows how long it's sat without a battery), and of course it didn't even want to turn over. The security light was on and the dash read "SERVICE THEFT DETERRENT SYSTEM", among several other things (4x4, Air bag, stabilitrak, traction control, and reduced engine power). Naturally, my first step was to disable VATS and rewrite entire.
After I did this, the engine turned and even ran for a second lol, and I presumed the dash reading of the VATS would go away. Is there a fuse or anything I can reflash this ECM to keep: A. The light from displaying and B. The Service Theft Deterrent System warning to go away?
Thanks for all your time, I've attached a brief scan file (nothing is hooked up so didn't run the engine for long) along with the factory tune and tune after the VATS deletion. I'm somewhat new to HP Tuners, so any help is appreciated!
01082020 1113 Factory.hpt
VATS Deletion.hpt
20-01-08 11-32-16.hpl
