I can't figure this issue out.
Recently I started seeing one of my widebands fluctuating AFR at idle and off a little compared to the other bank when I'm on the throttle.
I now have OBD2 codes for Cylinder Imbalance, lean codes and insufficient fuel flow code.
P0171
P0174
P219A
P219B
P2635
The FPCM is re-flashed for the ZL1 pump. I have a DSX flex fuel sensot kit and DSX auxiliary pump that kicks on at 4psi. I also have ID1300x injectors.
The car is a ProCharged 2010 Camaro SS A6 and has seen up to about 14psi boost at 6,800 rpm's but usually I see it in the 13psi range peak in this cold weather.
Log Layout:
Layout_01_06_20.Layout.xml
Log Channels
Channels_01_06_20.Channels.xml
Can't get the logs to upload here, but here they are linked to my forum: http://streetntrack.net/topic/2768-2...arger-d1x-tune
Scroll down and you'll see the files....
Mods:
Kooks Ceramic Coated Signature Series 1-3/4 to 1-7/8 Stepped Headers Part #22502300
Kooks full 3in exhaust with race cats Part #22505201 (Currently with Off Road Catless Pipes)
Trick Flow GenX 255's #TFS-3261T004-C01 (With Polished PAC .660's and Ti-Retainers)
Texas Speed VVT 3.2 cam kit & DOD Delete with Comp Cams VCT Limiter
Texas Speed 1.72:1 Ratio LS3 Steel Roller Rocker Arm Set w/ Roller Tip
AEM X-Series OBDII Wideband Gauges (PN#30-0333)
Fuel Injector Clinic ID1300x Injectors
GM Camaro ZL1 High Output Fuel Pump
DSX Tuning Flex Fuel Kit + E85
DSX Tuning Auxiliary Fuel Pump Kit
Mighty Mouse Camaro 5 Wild w/-12an and Billet Black
Holley Tall LS Valve Covers
JRE 6L80E Trans Dipstick kit
Tim King Built Stage II 1,000 HP CTSV 6L90E transmission
EARLS ULTRAPRO OIL COOLER PART# FP820ERL
EARLS OIL COOLER MOUNTING BRACKETS PART# 800ERL
EARLS oil cooler lines and -an fittings
Bowler 6L80-E / 6L90-E Transmission Cooler Manifold
DSS 3.5" aluminum driveshaft
BMR Driveshaft Safety Loop - Black Hammertone PN# DSL015
Circle D 6L90 LS Pro Series Stage III 258mm 3B 3200-3400
NGK Iridium IX spark plugs #7 heat range
DBR tuned via HP Tuners VCM Suite
Stage II ProCharger D1X with 3.9? pulley making 14psi
