Results 1 to 5 of 5
Thread: 2014 Raptor Select Shift wont work
    May 2018
    26
    Hi friend after download the tune the select shift wont work even if i put the base readed map on it
    no matter what i do the truck wont donwshift or upshift select shift via
    does any one have this issue before ?
    here attched the file
    Cesar H
    Toxic performance
    Apr 2018
    605
    I would try putting the Speedo settings back to stock and instead use the Scanner to set tire size, etc..
    Knock Retard is the reduction or prevention of knock by lowering ignition timing:
    (+) Adding Knock Retard = Reducing Timing. PCM is seeing knock.
    (--) Lowering Knock Retard = Increasing Timing. PCM isn't seeing knock.
    __________________________________________________ ________
    2014 Mustang GT Premium. VMP Gen2R Supercharged with an FTI 3000rpm Converter. JLT, BMR, Steeda, Viking, etc.
    Don't fix it if it ain't broken | Maximum effort gets maximum results
    Feb 2017
    TX
    761
    This happens when VID is disabled.
    Jun 2018
    Albuquerque New Mexico
    465
    Quote Originally Posted by Thatwhite5.0 View Post
    Does this happen even if your gear ratio, VSS Tire revs, and N/V base are set correctly? I think most cars/trucks just have generic data in all three of those tables which is why the shifting issue occurs when people set Use VID to disable.
    May 2018
    26
    Problem solved ... install the lastest software version and reinstall the map and thats it
    Thanks for the tips any way
