Results 1 to 20 of 25
Thread: 03 vs 04 cobra scaling
    i pulled the file off my 03 cobra and was comparing it to an 04 stock tune i pulled off of here. When i bought the car it was already tuned, so i wanted to see the changes made and i noticed a bunch of things off. the scaling on some of the tables are off between the two, one example is under idle tab ISC transfer function desired airflow is scaled 00.0 0.10 0.23 0.32 0.46 1.04 1.65 2.48 2.50 16.00 for the 03 and the 04 is scaled 0.00 0.13 0.26 0.38 0.58 1.06 1.53 2.07 2.55 2.62 another example would be under fuel tab Fuel cranking vs ECT the engine coolant temp (oF) is scaled starting from the top 65.534 110 68 50 20 0 -20 -40 -65.536 -65.536 -65.536 -65.536 for the 03 and for the 04 its scaled as followed 65.534 230 180 110 68 50 20 0 -20 -40 65.536 65.536 there a few more that are off too but its way to much effort to type it all in. now as far as i know those are not adjustable and i was wondering if the was a revision on fords end between years, i know my 03 is an early production canadian car and im assuming the 04 is an american car but would these values not be the same? any help would be great, i just want to have a mostly stock tune for my car for keeps sake
    pretty normal. but they are changeable
    The x and y axis scaling values I'm talking about not the adjustable parameters within the table
    yes
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    the only real way to check for changes, is to compare an identical car. the calibrations even though seemingly similar, are vastly different. making the mistake of trying to load values from one cal to another will give very unsatisfactory results. before we had hpt access to these cars, tuning was adequate at best, but if you look at files using binary editor, or tuner pro etc, you will see the vastly different calibrations ford used to control identical setups
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    You would think they are identical cars, that's why I'm asking if anyone knows if there has been a revision in software between those two years. Needless to say if anyone has a stock 03 cobra tune that would help me out greatly
    Jul 2009
    326
    If anyone has stock 2003/04 Cobra files in hpt format I would be keen to get a copy if possible! I have a a few reads of 01 Cobra?s and have an Eaton swapped 01 Cobra so need a good stock tune as a go by. I?ve pulled the 04 one off this forum already, I believe that?s a stock file.
    Mar 2010
    New Orleans, LA
    630
    all 03 and 04 cobras are interchangeable there were no calibration specific changes between the two years.
    theres a bunch of different cals for them but the most commonly used is the AMZ2 which uses the FBGI0 strategy. I use that same strategy for all the 02-04 GT's I tune as well.
    decipha @ EFIDynoTuning
    http://www.efidynotuning.com/
    Jul 2009
    326
    The Eaton swapped 02' Cobra (Its an Aussie import) I have still uses the stock strategy (CVAE7BZ) with very few changes! Can post if you're curious! Being an Aussie tuner, they wouldn?t have had SCT database access to the other Strategies (same as me).
    Do you recommend loading a 03/04 Cobra strategy into a 01 Cobra PCM (with an Eaton swap) as a base tune? I have simply edited the CVAE7BZ (strategy when the xcal1 was returned to stock) to be a 03/04 base tune....except things like final drive, fuel pump calibration, spark for higher comp etc. Waiting on parts so haven't tested it yet!
    The other 2002 Cobra I have here is an RVAF1C4.
    Jul 2009
    326
    02' Cobra with Eaton swap. Tune from a local shop....not for use as a go by!
    03/04 cobras dont have knock sensors and use another iat sensor down in the intake vally. The cams might be slightly different and compression ratios. Loading a 03/04 cobra tune could hurt it. You're best bet is to modify the 01cobra tune and be mindful if you use knock sensor that the blower will throw false knock
    Jul 2009
    326
    So far I?ve used the stock strategy and just changed all the tables to mirror a 03/04 Cobra. Compression is different, but yeah cams might be different also, good point. Knock sensor has been removed/disabled. Still waiting on parts so haven?t fired it up yet.
    How the tables are used may cause an issue using 03/04 values in a 01 strategy. I?m not well versed in what happens in the background with these...will find out when I start tuning it!
    It uses that second iat sensor to retard timing and add fuel instead of the knock sensor because of heat soak. I dont think that strategy would be implemented in a non f/I motor that uses knock. May be worth it to look into that
    Feb 2012
    TEXAS
    634
    Having issue with making a histogram. Trying to get STFT+LTFT to work with an 04 Mustang. Anyone have it working for them?
    Datalogging is currently not functioning with eecv. Best bet to log with another device until a fix comes out, if it does
    Quote Originally Posted by 03cobra_keek View Post
    well...it works,but just sketchy
    Feb 2012
    TEXAS
    634
    Yes, it is working with limited PID support. just trying to do STFT+LTFT but it is stuck on one cell in the table, just wanted to see if anyone else has a fix.
    Dec 2013
    Slidell, La.
    1,015
    if its stuck in one cell and not moving, thats because the table isnt properly setup. go into settings and make sure its logging the correct parameters for this ecu
    Michael Bray
    Slidell, Louisiana
    20yr Master Tech.
    Shop Owner
    Nov 2018
    Houston, TX
    Stock 03 cobra tune
    Little late but here is my stock 03 cobra tune. Pulled off my bone stock 03 with the MVPI2
    Feb 2012
    TEXAS
    634
    Quote Originally Posted by mstang_man View Post
    The cell is moving, it just fill the one cell it doesnt want to travel up and down the ad count/volts
