Hi,
I have LQ4 twin turbo in my -71 Camaro and currently it has 2003 Silverado Pcm, acc pedal, tac module and throttle body. Problem is that silverado pedal is modified shorter to fit Camaro and thats why pedal travel is way too short. Whit fast spool turbos car is difficult to drive.
I was thinking to change pedal, tac and throttle body from c5 Corvette (+ it should also be possible to use ls2 90mm throttle whit adapter/adapter cable in this combo).
So i am asking if someone has done this and know if will it work correctly? 2004 c5 even has same p59 pcm but not whit os that fit my flexfuel / 4L80e combo.
