Results 1 to 5 of 5
Thread: 2011 2500 HD E78 electric fans - patch or segment swap?
    Feb 2008
    Sikeston, MO
    173
    Didn't see that other people were having issues with this before buying the conversion kit. Truck will not run the fans. An earlier tune, they could be turned on with the scanner controls, but would not come on. I copied all the data over from an E78 Cruze, and they still will not function and even the scanner will not turn them on.
    I'm assuming no one has had luck? I'm thinking it will take a patch or a segment swap to fix? But there's no suitable segment swap donors I can find...
    Tuner 53mercury's Avatar
    Feb 2011
    Alberta, Canada
    96
    Hmmm I'm having the same issue! went from a 2008 truck (e38 pcm) to a 2012 corvette pcm (e38) :so tap shift could be used:. the problem is I plug in the old pcm, test the fans via scanner function and they work I plug in the new pcm and no go with the fans. like you I copied everything from one file to the other and still no go! did you find a fix for this? any info would be much appreciated.
    53 Mercury pickup triton3v V10 supercharged 150 nos 535rwhp
    71 Roadrunner gen 4 viper
    53 Chevy pickup 4x4 5.3L twin turbo
    7,566
    https://www.google.com/search?tbs=li...s.com+e78+fans
    Look through those, I don't know if there's a solution in there.
    Advanced Tuner IARLLC's Avatar
    Aug 2016
    942
    The Vette E38 had functional e-fans from the factory but they were run a little differently. Did you check everything? Fan output controls?
    Feb 2020
    14
    I was never able to get my fans running E78 ecm.. the scanner would ifact turn them on however it would not turn on with tune..
