Results 1 to 4 of 4
Thread: Need help fast!
    Dec 2019
    11
    Need help fast!
    so no matter what tune i go to my transmission will not work in reverse or drive. i tried to modify my airflow tables then tried to disable all torque management to isolate the issue and still no movement from the challenger. It used to run until this afternoon. all I can see is that the TCC is remaining Unlocked but i dont know how to fix thattransmission not working.hplsecond try at tune.hpt
    my parts
    P1 procharger
    Nov 2017
    816
    Flash it back to stock and see if it moves.
    Nov 2017
    816
    You've got 36020 & 36022 max torque brake on and brake off set to 0. That doesn't sound like a good idea. Not sure if it's the cause of your problem or not though.
    Dec 2019
    11
    I went back to stock and barely crawled into the garage. It's like there's 0 throttle response. And of course my bar is going to have to be reset. but it seems the throttle is delayed which causes the transmission to not lock up in to proper gear...
