Thread: 5.3 to 6.0 swap idle problem
    Mar 2015
    Dallas, TX
    39
    Hello everyone, what may be happening when I have a 5.3 pc and I convert it to 6.0 through a tune or a segment swap with the hp tuners, it has happened to me on several occasions that I start the start up is very high and very low slow, and on top of that the pcm commands an idle and the real one is usually 150 rpm above.
    All engines are stock only to have been displacement changes or be a swap of a 5.3 to 6.0
    what may be happening HELP HELP !!!
    13,565
    Copying 6.0 stock data over a 5.3 stock tune shouldn't be causing any sort of real issues if the 6.0 is indeed stock.
    Are the calibrations from the same exact year?
    Do you have data logs that show something going weird and causing the strange running issues?
    Mar 2015
    Dallas, TX
    39
    I thought so but apparently it's not like that, or I don't know if I have any mistakes, because it happened to me in several cases in both 3gen and 4gen
    20-01-14 17-17-05.hpl
    Carloos G 6.0 .hpt
    13,565
    That log shows other problems likely not caused anything tune related.
    Fuel trims are through the roof. Low fuel pressure or bad exhaust leaks could be causing that. The o2 sensors are very lazy as well.
    Never had any problems when copying over 6.0 data into a 5.3 file when swapping engines, so I don't know why you'd be having issues.
