Results 1 to 3 of 3
Thread: Tune Cabinet?
    Sep 2019
    6
    Tune Cabinet?
    I am told there is a tune cabinet that has several tunes that can be downloaded. How do I access that?
    Thank you
    13,565
    It's called the tune repository, it's on your customer page in what I believe is the devices section.
    I will warn you here, the repository and NOT a place where you should be going to find and use other peoples tunes. If you flash someone else's file into your computer you will only cost yourself money and perhaps a computer because you could turn it into a door stop.
    Use it only to reference information and if you choose to copy something, you better be damn sure that whatever you are trying to use is correct. Otherwise you are just putting yourself in a hole. The repository is best used for stock files that are wanted for various reasons.
    Sep 2019
    6
    That answers the question right there. Thank you
