Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
Thread: Having load drop on a 2017 3.5 ecoboost with crp turbos
    Oct 2018
    33
    Absolutely.
    Oct 2016
    Poland
    1,755
    Well increase this for starters - your map peaks around 2.3-ish BAR and you are only allowing LOAD to 2.1.
    Your LOAD should equals MAP for best results.
    Oct 2018
    33
    I had that at 2.3 with no change in behavior so I set it back stock.
    Oct 2016
    Poland
    1,755
    LOL set to 3 or even 4...as you can read it's labeled as MAX LOAD!
    Oct 2018
    33
    I had it at 3 as well and changed nothing.
    It follows the LSPI tables.
  6. #26
    Oct 2016
    Poland
    1,755
    Post a log with this raised to 3. LOAD clearly hanged around 2.1 exactly where it was limited.
  7. #27
    Oct 2016
    Poland
    1,755
    It's clearly not torque related but rather load related. Very simple to solve if you follow the trend...
  8. #28
    Oct 2016
    Poland
    1,755
    Here you go your tune was still limited in like 20 places - try this has to work.
    testing_1.hpt
  9. #29
    Oct 2018
    33
    I understand what you're saying. but i've done what you say to do, and it does not do anything at all. It trends down and the thing you're not looking at on your graphs for some reason is TIP actual vs TIP desired
    If you note as you watch it, turbo speed desired is less, TIP actual is higher than desired and it keeps desiring less and less TIP, desired load is well above actual and desired airmass is high.
  10. #30
    Jan 2020
    18
    Did you figure this out for your record run?
    This is my signature... haha
  11. #31
    Feb 2018
    Kuwait
    98
    Try rising the driver demand. I would change the predicted throttle angle and the effective area tables to force the TB to stay fully open. I also would rise the LSPI reduction tables to above 2.2
  12. #32
    Quote Originally Posted by w00t692 View Post
    Any update on the issue?
