Results 1 to 20 of 32
Thread: 18 and up Mustang Gt Burble
    Dec 2017
    767
    Has anyone done anything with the burble tab to add some pops on decel and in between shifts? Have a Customer that I have tuned his 19 and wants me to add that. Just looking for a bit of info how to increase the intensity of he wants it more aggressive. I see the bullit file is different with it then the normal Gt file.
    The bullit is factory enabled but it does not burble much with stock settings. You can lengthen the time and how easy it enables, but as far as between shifts I don't know, I've only played with it on my 10speed auto.
    Dec 2017
    767
    I have yet to play with that tab as far as changing the enable and disable and for how long, and suggestions at all to try?
    Dec 2017
    767
    So I tried the bullet settings and lengthened the times a bit hoping it would pop some. It didn’t, so I went back to the method of how I usually set of the spark tables to pop. Set my mbt tables From .20 load and under to 10
    Degrees across the board. Pops just like he wants but now he said he noticed the auto rev match does not function now. Could that be due to how I have the spark tables by any chance does anyone know?
    Feb 2017
    TX
    761
    You need to adjust dfco in the fuel tab and dfco in the torque ratio tables.
    Stock settings will have timing too advanced during decelerstion or on between shifts. It could be 30 to 50*. Mess with the ratio tables to get spark less advance until you get the sound you want .
    Dec 2017
    767
    I did - works just fine
    What did you do sir?
    Dec 2017
    767
    Once I made the changes I stated in the spark tables it gave him the sound he wanted , although I was trying to make the burble tab do the work instead. The issue now is after I nodded the spark tables his rev match does not function anymore. Trying to see if it’s a fluke thing or if changing the spark tables would have any affect on that which I’m doubting.
    Oct 2016
    Poland
    1,739
    Burble logic - works just fine. Play with setting a little it will do what you need.
    Dec 2017
    767
    I’ll keep trying just wish this car was closer to me so I could have more time to get this down. So if I wanted to increased the speed of how it pops and so on would I increase the duration in time or lower it?
    Oct 2016
    Poland
    1,739
    Don't go too far with burble or you will end up destroying your cats.
    Dec 2017
    767
    Thank you sir
    Jun 2016
    42
    Dec 2017
    767
    Thank you sir that is much appreciated!
    Aug 2020
    21
    I was messing around with burble on my 2020, this thread is very helpful. One thing that is strange is that the burble settings work great in sport, however they don't seem to work in normal. I have my sport and normal mode settings the same right now. The mag suspension only changes with the mode switch, so I want the burble to work when my suspension is in normal mode.
    Anyone have experience with burble in normal mode?
    Apr 2018
    605
    My friend's 2018 is the same. I setup Burble and it works great in sport mode. Does not work in Drive at all. There must be some logic which bypasses it in Drive (and possibly an unexposed parameter).
    I have a new tune to try to see if I could get it to work in Drive but waiting for the virus crap to settle down first
    Knock Retard is the reduction or prevention of knock by lowering ignition timing:
    (+) Adding Knock Retard = Reducing Timing. PCM is seeing knock.
    (--) Lowering Knock Retard = Increasing Timing. PCM isn't seeing knock.
    __________________________________________________ ________
    2014 Mustang GT Premium. VMP Gen2R Supercharged with an FTI 3000rpm Converter. JLT, BMR, Steeda, Viking, etc.
    Don't fix it if it ain't broken | Maximum effort gets maximum results
    Dec 2019
    Ohio
    19
    Has anyone tried it on the 2018 gt 6 speed manual
    Aug 2020
    21
    I have tried it on a 2020 6 speed. Great in sport, no difference in normal as far as I can tell.
    Aug 2020
    3
    Anyone have the bullit HPT file?
    Mar 2019
    Ogden, UT
    98
    Quote Originally Posted by Devirus69 View Post
    2019_Mustang_Bullitt_stock_file.hpt
    Here you go!
